Activity Forums Adobe After Effects Expressions spill suppression
  • Posted by Guillaume Charron on August 21, 2007 at 8:41 pm
    In shake we can supress the spill with some expressions in the color x node… for exemple:
    g>(b+r)/2?g=(b+r)/2
    Can we do that in shake? If yes, with which plugin? And of course, what could be the expression?
    Guillaume Charron replied 19 years ago 2 Members · 3 Replies
  • Guillaume Charron
    August 22, 2007 at 4:56 am
    I meant: “Can we do that in after effects?”
  • Filip Vandueren
    August 22, 2007 at 9:10 am
    In after effects expressions calculate the values of properties that can be keyframed. Not the RGB values of pixels.
    What your expression seems to do (green values may never be more than the average of red and blue) could also be done like this:
    Duplicate the layer,
    on the top one, add a channel mixer and change the green sliders to 50%red, 0%green, 50%blue.
    set the top-layer’s transfermode to darken.
    If the layer had an alpha, enable “preserve Transparancy”
    If you want to do it with just 1 1ayer you need “CC composite”, to darken the original back on the filtered output.
  • Guillaume Charron
    August 22, 2007 at 11:23 am
    thanks… I try that little trick. 🙂
