Activity › Forums › Zaxwerks › Sphere Rotate
  • Sphere Rotate
    Posted by Iu Video on November 9, 2007 at 4:40 pm
    I’m trying to create a sphere in PA and rotate it 360 degrees. Think of rotating a planet. I’ve added a texture bitmap to the sphere but I can’t seem to get the sphere to rotate a complete revolution. It almost looks as if PA is bending or morphing the texture map around the sphere. Ideas?
    IU Video
    Iu Video replied 18 years, 10 months ago 2 Members · 4 Replies
  • Jon Okerstrom
    November 10, 2007 at 1:11 am
    Hi IU Video,
    Are you doing this during a pose or a transition? Is the rotation the problem or is it the way the texture map looks applied to the sphere?
    Jon
  • Iu Video
    November 12, 2007 at 3:45 pm
    It is during a transition. When trying to apply during a pose, nothing seems to happen. The texture map looks fine (warped, as if it is wrapped onto the sphere), but it only seems to move about 90 degrees (we have it programmed for 360). We would like it to move at least 360 degrees, if not more.
    IU Video
  • Jon Okerstrom
    November 13, 2007 at 1:16 am
    Hi IU Video,
    Why not use a pose action… in your first pose, go to the pose action presets. choose spin y. move the rotation pointer so you get 360 degrees or whatever else you want.
    Jon
  • Iu Video
    November 14, 2007 at 7:44 pm
    Got it thanks for the help and guidance.
    IU Video
