Activity › Forums › Adobe Premiere Pro › Speeding up Warp Stabilizer in Premiere Pro CS6
  • Speeding up Warp Stabilizer in Premiere Pro CS6
    Posted by Tony Connoly on June 19, 2012 at 4:16 pm
    (i) I read that Warp Stabilizer is CUDA accelerated. Is the initial computation phase CUDA accelerated or only the viewing phase after the initial computation?
    (ii) I noticed that during its “background” computation phase, the Warp Stabilizer only uses one of the cores on my quad-core. Sometimes I actually would want it to use up all of the cores. Is there a way to do this?
    (iii) I just upgraded my computer to i7-2600K with 16GB RAM. Should I have gotten more RAM to make things faster?
    Mic Pool replied 10 years, 3 months ago 5 Members · 9 Replies
  • 9 Replies
  • Michael Murphy
    June 21, 2012 at 4:13 am
    If it is a primarily CUDA process, it is using the GPU’s, not the CPU’s, so a single CPU wouldn’t be a problem.
    You are probably OK on RAM. You can look at the database on ppbm5.com to compare your same CPU performance against machines with different amounts of RAM, disk drives, etc. If you have enough slots, I added 24GB (3x8GB chips) recently for $180.
    Is your card enabled for Mercury Hardware Acceleration? (CUDA cores.) If you had to do the hack, it needs to be done again when you upgraded to CS6.
    https://www.studio1productions.com/Articles/PremiereCS5.htm
    Michael
  • Tony Connoly
    June 22, 2012 at 5:01 am
    Michael,
    On my machine the GPU usage is 0% During the “Analyze in Background” phAW. cpu usage is around 40%
  • Jon Barrie
    June 22, 2012 at 5:41 am
    Pretty Sure the Analysis is happening all on the CPU, the playback of effects once its finished goes to GPU.
    Cheers JB
    Jon Barrie
    Adobe Video Solutions Consultant ANZ
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
  • Tony Connoly
    June 22, 2012 at 12:34 pm
    Is there any way to make the computation phase a foreground process?
    A two-minute clip took 30 minutes to process as a background process.
  • Michael Murphy
    June 23, 2012 at 5:26 pm
    Hi Tony!
    Sorry, lost track of this thread.
    There are two posts on the Adobe forum from 6/14 saying the same thing, that warp stabilizer is using CPU only. No response yet. I don’t knwwo if one is from you?
    https://forums.adobe.com/message/4493854?tstart=0
    I think there was a software update to version 6.01 around taht time. Did you install the update? Just wondering whether there was a bug that was fixed?
    I’m reading other things on teh Adobe forums, I’ll post if I see anything more on Warp & GPU.
    Best,
    Michael
    But theere is also this on the Nvidia site:
    Warp Stabilizer
    Now integrated directly into Adobe Premiere Pro, the Warp Stabilizer allows you to fix shaky footage while Rolling Shutter Repair helps eliminate rolling shutter artifacts. NVIDIA GPUs deliver real-time previews and fast exports of this footage.
  • Tony Connoly
    June 24, 2012 at 3:49 am
    Michael,
    I think those posts are referring to something different. I struggle with “phase I” of the stabilization, where it says “analyzing in background (step 1 of 2)”. This is very slow for me, and the GPU does not kick in by design I think.
  • Michael Murphy
    June 25, 2012 at 3:07 am
    OK, got it.
    You might try to use Warp Stabilizer in After Effects for comparison.
    There is an option there on how many CPU’s to use, and how much RAM per CPU.
    If you have a web site to post a test project for download, we could compare timing to render on different machines. That might tell you if there is a glitch in your setup?
    Michael
  • Brandon Engelman
    January 13, 2015 at 9:09 am
    I found a fix. You break the clip up into pieces and run the analyses simultaneously.
  • Mic Pool
    June 2, 2016 at 10:21 pm
    Thanks very much for this. I am warp stabilising 90mins of footage shot from a suction mount on the side of a train. It was going to take 20 hours. By splitting it into 8 layers it will take 3
    Brilliant!
