Activity Forums Apple Final Cut Pro Legacy Speeding up Voice over in FCP or Soundtrack?
  • Pierre
    August 7, 2006 at 9:17 pm
    Actually I figured it out… my next question though. I’m trying to make the Voice over sound like it’s OLD and from the 30’s or 40’s. Any filters that you recommend?
  • Tom Brooks
    August 7, 2006 at 9:53 pm
    Back then, all you had was radio. A tabletop or console type of radio. So roll off the high and low frequencies for a start (to taste) and experiment with a slight boost (parametric EQ) added to the signal at the frequency of your choice–anywhere from 300-2000Hz–whatever sounds right to you. Then add some noise. Maybe there’s a good noise sample in ST Pro?
