Activity Forums VEGAS Pro speeding up video by increasing framerate?
  • speeding up video by increasing framerate?
    Posted by Ryan Laurence on May 6, 2016 at 8:34 pm
    I recorded some video with OBS at 5fps for a time lapse. I was hoping I could just change the project frame rate to 30 fps to effectively speed up the video 6x, but instead it just adds more frames between each recorded frame making no difference to playback speed.
    Is there a way I can get rid of these extra frames to shorten the video? (vegas pro 13)
    Graham Bernard replied 10 years, 4 months ago 3 Members · 3 Replies
  • Wayne Waag
    May 7, 2016 at 12:00 am
    There are a couple of ways you might try. First, simply ctrl-drag the end of your timeline to the left. However, I believe there is a 4X max. Also make sure that you disable smart resample so you don’t get ghosting. Second, and probably better. First export your 5 fps video as an image sequence–e.g. png’s. Then re-import the images as a sequence indicating the frame rate to be 30 fps. This should result in a 6X speed up. Set your project frame rate to 30 fps.
    wwaag
  • Ryan Laurence
    May 7, 2016 at 12:13 am
    Ah using an image sequence might work for me. I went ahead and just sped it up a couple times by importing my project into a new project, but I’ll give that a try next time. Thanks.
  • Graham Bernard
    May 7, 2016 at 2:50 am
    To get greater than 4x use the Velocity Envelop in conjunction with CTRL+Drag right.
    * Grazie
