Activity › Forums › Audio › Speeding up audio recording of piano
  • Speeding up audio recording of piano
    Posted by Harry Bromley-davenport on February 6, 2012 at 8:36 pm
    I have an .aif file of some solo piano music for use in an FCP sequence. Rather than edit the music to fit, I would prefer to speed it up by 10% or so.
    When I try this in Final Cut (using the Apple AU plugin) in Soundtrack Pro or Protools 9, I can only get to about +5% before I start hearing nastiness. I reckon that this is because, in the speeding up process, it sounds as if it starts to chop out the attack portions of some of the piano notes.
    I don’t mind if the audio goes up in pitch by 10%, as per old analog tape, but this won’t do.
    Does anyone know of a way of speeding up this type of audio satisfactorily?
    With many thanks,
    Harry.
    Bob Kessler replied 14 years, 7 months ago 3 Members · 3 Replies
  • Ty Ford
    February 7, 2012 at 12:22 am
    Hello Harry and welcome to the Cow Audio Forum.
    10% is pretty severe for speeding up and VERY severe for slowing down.
    I suggest you pursue your first idea and edit it;at least far enough down so that you’d only have to smoosh it 4%-5%.
    I do that with tracks all the time. I’d do it in STP or Pro Tools.
    Regards,
    Ty Ford
    Cow Audio Forum Leader
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
  • Harry Bromley-davenport
    February 7, 2012 at 4:56 am
    Thanks very much for the advice.
    Harry
  • Bob Kessler
    February 7, 2012 at 4:50 pm
    I’ve had a lot of luck with Serato Pitch ‘n’ Time. Surprisingly seems to work better on “dense” music like a full band or orchestral material rather than solo instruments like a violin or piano. Sometimes I will have to do it 2% or 3% at a time rather than all at once. Even PTs time compress/expand tool does a decent job as long as you don’t do it all in one shot.
    Peace,
    Bob
    ____________________________________________________________________
    Filmmaking is the art of the invisible;
    If anyone notices your work you haven’t done your job right.
