Activity Forums Adobe Premiere Pro Speed up entire project
  • Speed up entire project
    Posted by Anthony Uccello on January 18, 2011 at 6:31 am
    I have a project full of keyframes, images and effects, and audio. The whole video is 80 seconds and I want it to be 60 seconds.
    Is there a way to speed EVERYTHING up on the project?
    And for bonus points is there a way to lower the tone on the audio so that when I speed it up it doesn’t get so squeeky?
    Andrew Devis replied 15 years, 7 months ago 3 Members · 4 Replies
  • Greg Brand
    January 18, 2011 at 10:32 am
    Probably the easiest way would be to nest the comp.
    then Retime it in the new sequence. I believe the Speed and Duration setting allows for maintaining Audio pitch, but in my experience that never works to well. if you speed it up or slow it down, the pitch will change. not sure how one would correct that.
    hope that helps.
    https://gregbrand.co.uk
  • Andrew Devis
    January 18, 2011 at 4:06 pm
    You could nest the sequence in a new sequence and use the rate stretch tool to pull it back to 60 seconds..
    … because it’s all about stories …
  • Anthony Uccello
    January 19, 2011 at 5:40 am
    Thank you is there a tutorial on this?
  • Andrew Devis
    January 19, 2011 at 8:03 am
    Hi Anthony
    It is the next tool tutorial I have planned, so there will be one in the next couple of weeks. Sorry its not available now.
    Andrew
