Activity Forums Maxon Cinema 4D Speed up dynamics
  • Speed up dynamics
    Posted by Rick Morton on May 3, 2017 at 3:55 pm
    I’m trying to make a block of concrete fall to the ground and break apart. Not a problem so far. Collider floor and Rigid block in Voronoi. Drops and cracks apart. But I want it to fall FASTER so it looks a bit more violent when landing. Can’t find a setting for that. ???
    Also, is there a way to change the angle at which it comes in?
    The example I’m after is in this Andrew Kramer tutorial. Notice how fast the block is falling.
    Thanks.
    https://www.videocopilot.net/tutorials/depth_compositing/
    Adam Trachtenberg replied 9 years, 3 months ago 2 Members · 3 Replies
  • Adam Trachtenberg
    May 3, 2017 at 4:05 pm
    The easiest way to speed up dynamics is to change the time scale setting in Edit>Project Settings>Dynamics.
    For example, if you set it to 200% the simulation will be twice as fast.
    Another option would be to increase the gravity setting.
  • Rick Morton
    May 3, 2017 at 5:05 pm
    Thanks. I’ll look for that.
    Haven’t seen any GRAVITY settings, though. And I thought of that first.
    Seems like it should be VELOCITY… but those settings don’t seem to anything.
  • Adam Trachtenberg
    May 3, 2017 at 9:55 pm
    Gravity is also in the project settings (which seems stupid).
