Activity › Forums › Apple Final Cut Pro Legacy › Speed Up 720 24P footage
  • Speed Up 720 24P footage
    Posted by James Mulryan on September 20, 2006 at 5:57 pm
    I shot a few pans that I would like to speed up. When I use the modify speed command, the footage does not look smooth. I have frame bending on and am trying to increase the speed by 50 percent.
    Any suggestions would be greatly appreciated.
    Mark Maness replied 20 years ago 2 Members · 1 Reply
  • Mark Maness
    September 20, 2006 at 7:25 pm
    [James Mulryan] “I shot a few pans that I would like to speed up. When I use the modify speed command, the footage does not look smooth. I have frame bending on and am trying to increase the speed by 50 percent.
    Any suggestions would be greatly appreciated.”
    Well, if you have Shake, it will do awesome slo-mo OR the Twixtor plugin. Motion does ok, but can be difficult to use. FCP’s slo-mo has something to be desired.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
