Activity Forums Adobe After Effects Speed graph spike
  • Speed graph spike
    Posted by Dominic Plaza on October 7, 2013 at 11:05 am
    I just did camera tracking in After Effects “Track Camera” and when it’s done I created the camera. The camera holding values and on one part in speed graph there is a spike. The value graph looks perfectly. I can’t add 3d elements to the scene because in the place of the spike the whole scene is shaking. How can I remove that?
    Value
    Speed
    Roland R. kahlenberg replied 12 years, 11 months ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    October 8, 2013 at 9:47 pm
    The solved camera that AE creates contains KFs for Position and Orientation. To view the position KFs (Motion Path) for the camera in the Comp Panel, switch to a 3D view that allows you to view the active/solved camera visual representation. You should be able to view the camera’s Motion Path to identify the problematic KF.
    I suggest that you switch to 2 Views so that you can view the Active Camera view while you adjust/delete the problem KF.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
