Activity Forums Adobe After Effects Speed graph – I don’t understant why my curve go under “0”.
  • Speed graph – I don’t understant why my curve go under “0”.
    Posted by Simon Gomes on April 11, 2015 at 9:58 pm
    Hi ! I’ve a problem ! I would like to make a « smooth zoom » with a camera. She must begin very slow and have a high speed (very smooth) in time of 4 secondes. Then a little decrease. In the position graphic edit, when i put a slow value in px per second at the beginning and an high value at the end , and when i « play » with the velocity and the influence to have a pretty soften decrease and increase, the z position go under « 0 » and the camera go back in other sens. Anyone have a solution ?:) Sorry for my english, i’m from Belgium ( a little country in the center of Europe ^^)
    This is a capture of my graph, in white obviously the curve i which.
    Simon Gomes replied 11 years, 3 months ago 2 Members · 4 Replies
  • Tudor “ted” jelescu
    April 12, 2015 at 7:00 pm
    You can play with the curves, however you can avoid all of this by using a camera rig (Maltaannon has a great tutorial on that: https://maltaannon.com/articles/after-effects/simple-camera-rig/ ).
    When you’re writing “zoom” I think you’re referring to a camera travel in Z space, cause that’s what I see in your setup. If you want to actually animate the zoom use the controls from the camera layer.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Simon Gomes
    April 12, 2015 at 7:52 pm
    Yes in fact i wish making a travelling in Z not a Zoom. I prefer doing this by myself and not buying simple camera rig.
    You don’t know why i can’t do this tricks with the curve?
    April 12, 2015 at 11:09 pm
    You can watch the tutorial and build the rig yourself, you do not need to buy it. As a second option you can use 2 Null layers. Link the Camera to the first Null and use that for the first part of the move. Link the first Null to the second Null and use that for the second part. This should eliminate any issues you’re having when you try to animate the travel on the z axis with one Null only.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Simon Gomes
    April 13, 2015 at 5:49 pm
    I made by myself a camera rig today for the x, y z position and for the rotation x y z. It work perfectly but i definitly don’t know how he does the slider for the speed position 🙁 I don’t know what expression to pick and what expression on what null object.
