Activity › Forums › Adobe After Effects Expressions › Speed expression with keyframes
  • Speed expression with keyframes
    Posted by Lloyd Alvarez on August 30, 2012 at 4:59 pm
    I have a layer speed controller that works great without keyframes but would love to add keyframable speed. Here is what I have now:
    spd = effect(“Slide Speed (px/sec)”)(“Slider”);
    [time*(spd), 0];
    This makes the layer ‘slide’ at the speed set in the slider. Problem is that is I keyframe that value then the speed transition no longer works. How can I modify the expression so that I can keyframe the speed and the layer continues in the place but at a different speed?
    Dan Ebberts replied 14 years, 1 month ago 2 Members · 3 Replies
  • Dan Ebberts
    August 30, 2012 at 6:11 pm
    Lloyd,
    It sounds like you need a linear keyframe integrator:
    https://www.motionscript.com/articles/speed-control.html#linear
    Dan
  • Lloyd Alvarez
    August 30, 2012 at 6:38 pm
    Hi Dan,
    Thanks that is exactly what I was looking for. Should have checked your site! Love the new design by the way.
    One note, though. If you use Hold keyframes you get a bump in the value graph:
    Works great with linear keyframes. 🙂
    https://aescripts.com
  • Dan Ebberts
    August 30, 2012 at 9:22 pm
    Lloyd,
    Good catch. I didn’t really think about hold keyframes. You just have to replace the last line of the for loop with:
    v2 = spd.valueAtTime(k2.time-.001);
    accum += (k1.value + v2)*(k2.time – k1.time)/2;
    It’s a tiny bit less accurate, so I don’t think I’d use this version with linear keyframes, but it seems to get the job done for hold keyframes. I’ll have to update the article. Thanks!
    Dan
