Activity › Forums › Apple Final Cut Pro Legacy › Speed Change setting
Posted by Daryl K davis on April 19, 2007 at 2:01 amTrying to change speed on some clips. I type in 175% and it gives me 175.42% one time, I try again and then it’s 175.36 and so on.
How do I get the speed change I actually type in?Thanks
DK Davis / Editor/ Post Super
————————-Jeremy Garchow replied 19 years, 4 months ago 2 Members · 9 Replies -
Jeremy Garchow
April 19, 2007 at 2:20 amIt’s rounding to the frame. Perhaps 175% doesn’t translate to a specific frame. But the number of frames chosen probably translates to the fraction of a percent.
Jeremy
Daryl K davis
April 19, 2007 at 2:34 amAh, I see in this case that may be so. But it happens on many occassions when I use other percentages. 40% becomes 41.2%, and so on.
Is there ‘set’ speed changes that translate to the frame accurately?
Jeremy Garchow
April 19, 2007 at 3:00 amSame thing. It has to do with the number of frames you have chosen to slow down in relation to the number of frames you are trying to ‘create’ or fit into a specific time. Why do you need an exact percentage?
Daryl K davis
April 19, 2007 at 3:52 amThe HD conform place keeps grumbling about why the speed changes are such fractional numbers.
Daryl K davis
April 19, 2007 at 5:40 amYes. The speed thing hasn’t really been a major problem, it’s just that the on-line editor wondered why I always had such weird speed change percentages.
Jeremy Garchow
April 19, 2007 at 2:31 pmGot ya, tell them it’s all math. Are they doing the online in FCP?
Daryl K davis
April 19, 2007 at 3:26 pmYeah, this particular facility been a FCP shop for a number of years now. All-in-all the process works fine with FCP. This is my second MOW with them but I’ve done over 60 TV episodes there as well. All pretty much the same process: Shoot film or HDCAM-24p, off-line in SD with DVCAM downconverts, email media managed project file or EDL back and on it goes.
Jeremy Garchow
April 19, 2007 at 3:32 pmCool, then they should have ‘no’ problems with the online then, right? They should understand if they work in FCP.
Jeremy
