Activity › Forums › Avid Media Composer › SpectraMatte Key effect
  • SpectraMatte Key effect
    Posted by Jack Entonces on July 21, 2007 at 7:01 pm
    hello,
    I did a “highlight” effect yesterday at work. It was a black and white
    surveillance tape where you see the bad guy hold up a liquor store,I wanted to highlight the bad buys head with a light round circle.
    On v2 I used a SpectraMatte Key and set to 50 opacity.
    On v1 clip i used an animmate key with circle..
    It all worked perfectly except after I rendered and played back
    the clip on v2 withthe SpectraMatte was fuzzy, glimmery, real bad
    . Anyone have an idea why this happened, or how can i do this effect without fuxxy video on v2?
    thank you!
    Jack Entonces replied 19 years, 2 months ago 3 Members · 4 Replies
  • Jack Entonces
    July 21, 2007 at 7:02 pm
    on v1 , Spectramatte
    v2 annimatte
  • Grinner Hester
    July 21, 2007 at 7:35 pm
    I’m not following why your using spectramatte. Are you keying something?
    I usually use a color effect on v1 and crank down the brighness just a bit, then on v2, I use another color effect to brighten up what I want brightened then I nest animatte to cut it out.
  • John Pale
    July 22, 2007 at 6:55 pm
    You can actually do this entirely with the 3D warp effect….no color effects, animattes, or layers….unfortunately I am not in front of the system right now and can’t give you a step by step from memory.
  • Jack Entonces
    July 25, 2007 at 5:06 am
    hey Grin:
    thanks for the reply.
    I ‘m only using the Spectra matte because I saw someone else use
    it to create a highlite. But the color effect sounds like an easier way to go. I tried it and it worked. thanks!
