Activity › Forums › Apple Final Cut Pro Legacy › speckles on moving image Part 2
Posted by Videobiker on August 18, 2005 at 12:22 amSo I have tried everything. Replaced the originl file, re-applied my basic motion(scale and rotation), re-rendered and STILL have these damn speckles!
My timeline is DV, images are high res(aren’t they always?), can anybody give me aany more help? I have done everything tthat Bogiesan mentioned andd nothing has changed.
Biker
Annaël Beauchemin replied 21 years, 1 month ago 2 Members · 4 Replies -
Videobiker
August 18, 2005 at 12:28 amMore info….If I do NOT apply rotation there are no speckles. I am at a loss…….
Annaël Beauchemin
August 18, 2005 at 12:48 amFCP 5 has a better scaling engine which gets rid of that problem.
If you’re trying to get good results with 4.5, then reduce the resolution of your image in photoshop. If you need a very big resolution to do a big zoom, then you need to reduce detail in your picture (use Dust and scratch filter in PS).
If this fails, then you can try a little blur or the filcker filter, but at this point, you’re better going to After effect… in fact, AE is much better than anything else for pan&zoom. Because of the quality and the toolset.
But be sure to always monitor the result on a monitor and don’t judge with the RT preview… it will always look sharper when you render.
Videobiker
August 18, 2005 at 2:26 amCoyote
I am using 5.0.2 on a dual proc. G5. I noticed that later in my timeline there are 2 full screen aerial shots….I have the same type of scale and rotaion on them as I do on the stills giving me problems….the difference is that the problem stills are not full screen, they are portrait scans about 540×500. I can’t scale to fit the screen cause I lose detail on the still that I need for the story….It sits over a background layer that I have applied a saphire glow too.
When I scale only there is no problem but when applying the slightest bit of rotation I get the speckles and all kinds of tearing/aliasing along the right edge of my still.
The other shots on the other hand fill the screen and have no problems what so ever. Strange, huh?
I was hoping not to have to go to AE but it looks like I may have to. What about motion? How easy is it to do this in motion, the layering, etc.?
TIA
Biker
Annaël Beauchemin
August 18, 2005 at 2:47 amin your sequence settings: video processing tab, is Quality set to normal or best quality (ie, it’s NOT set to Fast) ?
are you fully rendering? You can’t judge the RT rendering on stills. Make sure the rendering status above your still is light purple-grayish. If not, render.
you didn’t tell me if you were seeing the problem on an external video monitor. This is important.
btw, to reply, use the “Reply to this post button”. It makes reading on the forum easier.
