Activity › Forums › Adobe Premiere Pro › Specify frame number for DPX export?
Posted by Ivan Myles on July 15, 2013 at 3:28 pmI am replacing a short clip in a DPX image sequence. Is there a way to specify the starting frame number instead of having the exported file start at frame 0000? Thanks.
Tero Ahlfors replied 13 years, 2 months ago 3 Members · 4 Replies -
Tero Ahlfors
July 15, 2013 at 3:30 pmNo can do and that’s one of the things I really want in Premiere.
Request it here: https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
Angelo Lorenzo
July 15, 2013 at 7:04 pmIn the interim, if you have Speedgrade, you can rename the clip in the file browser window and select a starting frame number. Bridge also has a batch rename but Bridge is also insanely slow.
Angelo LorenzoNeed to encode ProRes on your Windows PC?
Introducing ProRes Helper, an awesome little app that makes it possible
Fallen Empire Digital Production Services – Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire – The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
Can your post production question fit in a tweet? Follow me on Twitter -
Tero Ahlfors
July 15, 2013 at 8:21 pmOr bring the project into AE where you can set the export frame number.
