Activity › Forums › Avid Media Composer › SpecificSRconverterBase ERROR
  • SpecificSRconverterBase ERROR
    Posted by Jason W. miltt on February 20, 2006 at 11:23 am
    SpecificSRconverterBase too few samples in destination buffer ERROR
    I get this message when i try to export my audio tracks. I tried to mix down and i get it too.
    I tried on a different com0puter and it appears too.
    i tried on 4.6 and 5.0 with qt 6.5 and 7.
    same error on both
    I need to export the project but i cant!
    what can i do?
    Jon Zanone replied 20 years, 7 months ago 2 Members · 1 Reply
  • Jon Zanone
    February 20, 2006 at 4:12 pm
    Are all your audio tracks set to the same sample rate? For instance, if you imported music from a CD, generally (specifically commercial CD’s) will have a sample rate of 44.1. DVD standard is 48. If that indeed is the problem, mark an in and out on the whole sequence, right click on the sequence and select transcode. If your destination is DVD, selece 48.
    To avoid that problem in the future, you can automatically change the sample rate on import. It’s in audio project in the settings, but I’m not in front of an Avid, and my brain isn’t working….
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
