Activity Forums Adobe Illustrator Special Continuous Inner Path Effect
  • Special Continuous Inner Path Effect
    Posted by Douglas Kerr on May 17, 2011 at 12:51 pm
    Hi All,
    I am trying to create a continuous path from the outline of a shape that then moves inside the outline spiralling towards the center of the object, essentially filling the inside shape. I am looking for an automated way as manually, i skew the angles and ends up messy and I have I have lots of vector shapes that need the same effect. The end result needs to be 1 continuous path. Would it be possible to create a script to do something like this? Thanks for any suggestions.
    Here is a bad example to give you a rough idea, except without the connecting lines. https://tinyurl.com/6hnsrej
    thanks, Doug
    David Cabestany replied 15 years, 4 months ago 2 Members · 1 Reply
  • David Cabestany
    May 20, 2011 at 3:45 pm
    Use the offset path command, Object>Path>Offset path.
    You can assign a shortcut to it, so you don’t have to go the menu each time.
