Activity › Forums › Adobe After Effects › Sparkle or glittery effect…
Posted by Daniel Elder on July 25, 2006 at 4:04 pmI am trying to make a convinceing sparkle, glimmer for a product, and want to know what the best technique to use, would it trapcode particular or a standard plugin for AE 7? What settings should I try using for whichever plugin I would use? Thanks
Daniel Elder
Associate Producer
http://www.luminair.comWildfire replied 20 years, 2 months ago 4 Members · 5 Replies -
Nicholas Toth
July 25, 2006 at 4:49 pmI don’t think you’re being clear enough. What do you mean sparkle? Lense flair? Glow?
Try to find something to compare it to. -
Daniel Elder
July 25, 2006 at 6:21 pmI am looking for a sparkle that would make a product glow, it would be very simple, a few stars, no movement, just an adjustment of the brightness at a random, and has a very shiney kind of situation. I don’t know how best to describe it, but it would be something like “The Fablous life of the Rich and Famous” something more like a glitter. That just highlights the product. Does that help at all?
Daniel Elder
Associate Producer
http://www.luminair.com -
Mike Clasby
July 25, 2006 at 8:15 pmFear not to do an Advanced Search, just be sure to choose:
Search Terms – Sparkle
(and most impostant to search all the way back)
How far back do you want to search? – choose – “All Active Posts”
Search the Archives? – choose – Yes
This post made a nice Big Smile Sparkle, (zip file):
Date: May 15, 2006 at 9:52:06 am
Subject: Re: Smile twinkle.No need for a plugin. I do this a few times a year and have made a graphic to use over and over.
http://www.treelineproductions.com/preview/starsparkle.psd.zip
Add the psd to your comp and keyframe the scale from zero to whatever size you want then back down to zero. At the same time, keyframe the rotation from zero to, say, 180.
So, you should have 3 keyframes for the scale, and 2 for the rotation.
Easy.
Good luck!
Jon
TreeLine Productions
Fort Collins, CO USA——————————————–
Or this,
Date: Jul 1, 2005 at 12:10:45 pm
Subject: Sparkle effecthttps://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=2&postid=855276
Maybe a particle generator, Particular or Particle Illusion (lots of presets0 with lowered opacity.
Daniel Elder
July 25, 2006 at 9:26 pmThank you I forgot to do the advance search, but thanks for the advice.
Daniel Elder
Associate Producer
