Activity › Forums › Sony Cameras › Spanning recording over two sd cards
  • Spanning recording over two sd cards
    Posted by Mark Gilmour on July 9, 2012 at 1:04 am
    I own a Sony NX5U camera and love it. However, I have recorded events that span across two sd cards. The video never loses a frame during the span but the audio loses 28-29 frames at the very end of the first card immediately before the span. Is anyone familiar with this and is there a solution? Thank you for your help and response.
    Mark Gilmour replied 14 years, 2 months ago 3 Members · 3 Replies
  • John Lenihan
    July 9, 2012 at 12:39 pm
    Mark,
    Are you using the Sony provided Content Management Utility to bring the files to your computer?
    I had audio drops at the file closure points when I tried to use a different method, but not when I use CMU software.
    JOhn
    John Lenihan
    LeniCam Video Productions
    https://www.lenicamvideoproductions.com
  • Ian Cook
    July 9, 2012 at 1:13 pm
    CMU will concatenate the files into one clip with no dropouts
  • Mark Gilmour
    July 9, 2012 at 4:10 pm
    Hi, Thank you guys for your responses. I have the CMU disc but it says it is for PCs working with Windows programs. I use Final Cut Pro 7 and log and transfer works fine except where the spanning from card A to card B takes place. That is where the audio only loses the frames.
