Activity Forums Adobe After Effects Expressions sourceText.split problem
  • sourceText.split problem
    Posted by Chris Scalzo on June 18, 2018 at 7:23 pm
    in a range selector, I have the following code on a color amount. If the 10th word starts with an “s” or S”, I want it to change the color.
    The problem, is if a word before it has 2 spaces before it. It advances the split count; however, the range selector that doesn’t count the double space as a word. (so word 10 is now at text.sourceText.split(” “)[11])
    Anyone have any idea of a workaround?
    y=text.sourceText.split(" ")[10][0];
    if ((y == "s") || (y == "S")) 100 else 0
    Dan Ebberts
    replied 8 years, 3 months ago
    2 Members · 2 Replies
  • Chris Scalzo
    June 18, 2018 at 8:54 pm
    I found my workaround in this post from the great Dan couple years ago.
    https://forums.creativecow.net/readpost/227/33812
    Answer: expression selectors.
  • Dan Ebberts
    June 18, 2018 at 8:57 pm
    Try it this way:
    txt = text.sourceText.replace(/ +(?= )/g,”);
    y=txt.split(” “)[10][0];
    if ((y == “s”) || (y == “S”)) 100 else 0
    Dan
