Activity Forums Adobe After Effects Expressions Source text linked to TSV, but how to add Slider to choose columns from TSV
  • Source text linked to TSV, but how to add Slider to choose columns from TSV
    Posted by Bas V breugel on June 28, 2022 at 7:49 am
    Hi all. I have linked a tsv file to my text layers. But because I will have alot of precomps later, and a lot more of columns, I would like to have a slider control in the main comp so all precomps can go to the next column by changing slider value.
    I’m not too familiar with scripting/expression and tried to pickwhip the values. Then the expression fails as you can see in printscreens.
    Does anyone know how this can work?
    Filip Vandueren replied 4 years, 2 months ago 3 Members · 5 Replies
  • Filip Vandueren
    June 28, 2022 at 10:38 am
    Can yo check if the tsv file is a clean txt file without any other formatting/metadata ?
    The error seems to suggest the problem is with the data, not your code.
    Can you see the automatically created data-links when you drop the tsv file into a comp ?
  • Bas V breugel
    June 28, 2022 at 11:11 am
    Hmm, data seems to be all right. And when manually changing values it reads out the DATA.tsv perfectly.
  • Chris Voelz
    June 28, 2022 at 12:56 pm
    It looks like your slider is using a comma as a decimal point. The text data index is expecting 2 values but since there is a comma it is interpreting that as 3 values and breaking. Try replacing the comma on your slider using a .replace(‘,’ , ‘.’) function. Should be able to pick whip the slider on itself and add that to the end. This is just a theory since how you have it set up should work.
  • Bas V breugel
    June 28, 2022 at 1:16 pm
    Hmm very vague, just like that it does work. Seems like whenever the slider goes to pull from a blank cell in TSV it breaks.
    footage(“DATA.tsv”).dataValue([comp(“MAIN comp”).layer(“COLUMN_TSV”).effect(“Column”)(“Slider”),thisComp.layer(“ROW_TSV”).effect(“Row”)(“Slider”)])
    But I’ll take that, just making a backup layer containing the //code to copy paste whenever I accidently ‘slide’ too far.
  • Filip Vandueren
    June 28, 2022 at 1:23 pm
    I’ve tried to replicate the error, but it works for me.
    Try adding .value after each (“Slider”) to explicitly get the number ?
    and maybe also Math.round(…(“Slider”).value) to make sure it’s an integer ?
