Activity › Forums › Adobe After Effects Expressions › Source point along a path
Posted by Syed Iqbal on January 13, 2006 at 1:49 amDear friends
I have an image and want shine effect’s source point property to travel along a path that I drew using the pen tool on a different layer.Any hints to get this done properly.
Syed Iqbal replied 20 years, 8 months ago 4 Members · 6 Replies -
Videobill
January 13, 2006 at 2:14 amHi TweenGuy
I am new to the cow, but I will do my best in repley, and I am sure others may have other ways to do this.
1)Copy the key frame or frames of your path (or mask) to an adjustment layer.
2)Then go to you layer that contains the shine effect and alt click on the Source point
to create an expression line.
3)Then attach your expression to the position of of the new adjustment layer that you created. (adjust keyframes if needed)Hope this helps!
Videobill
Wysee
January 13, 2006 at 2:18 amHi,
yep that’s it.
I just suggest you to use a “null object”, that’s made for this.welcome and enjoy Videobill.
wysee
Steve Roberts
January 13, 2006 at 2:20 pmYou can also just copy the path’s “mask shape” property and paste it to the Shine effect’s “source point” property in the timeline.
Steve
Syed Iqbal
January 13, 2006 at 7:28 pmThanks to Steve, wysee and videobill
Steve, I have noticed that the path shape enlarges itself when copied as the source point property. Why is that?
Anyways, I have tried to fix it by scaling down the shine layer and also by moving the same in x and y coordinates to get the source point moving exactly at the correct position. Do you think this is the right way?
Steve Roberts
January 13, 2006 at 8:01 pmAre the masked layer and the shine layer the same size? If not, you’ll see a discrepancy.
Steve
Syed Iqbal
January 14, 2006 at 7:25 amHi Steve
Yeh, all the layers are 640×480 including composition itself, but the path shape copied is bigger than the original path shape on a null layer.
