Activity › Forums › Adobe Premiere Pro › Source Monitor Output to External Display
Posted by Daniel Miller on July 8, 2013 at 7:55 pmI’ve got a Mac Pro on 10.7.5 with a Black Magic Intensity Pro, newest drivers and Premiere CC. Can someone tell me if there is a way to spit out what is in the source monitor to my external display? This worked beautifully with my kona lh and fcp 7. I feel like I have to be missing something and all my googleing has yielded nothing. Thanks in advance!
Ericbowen replied 13 years, 2 months ago 5 Members · 9 Replies -
Chris Conlee
July 8, 2013 at 9:37 pmIt’s been a year since I worked with PP CS6, but I had the same issue. I think the problem is that the BM card doesn’t have hardware scaling, so unless you’re working in an HD project, you won’t get client monitoring of your source.
However, at least for me, when I used the Matrox MX02 mini, it worked beautifully. Again, I’m assuming because the Matrox box had hardware scaling built in?
Anybody confirm?
Chris
Shane Ross
July 8, 2013 at 9:53 pmI can confirm that the Matrox has hardware scaling, up and down. I believe the BMD cards have hardware downscaling, but not upscaling.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Daniel Miller
July 8, 2013 at 10:09 pmWhat if I don’t need upscaling? shouldn’t a 1080p tv be able to display 1080p footage(if the frame rate is supported)?
Peter Garaway
July 8, 2013 at 10:39 pmYes. The Intensity Pro should be able to output to the following formats:
1080p23.98, 1080p24, 1080p25, 1080p29.97, 1080p30As long as your monitor supports it there should be no problems.
Peter Garaway
Adobe
Premiere Pro -
Shane Ross
July 8, 2013 at 10:46 pm1080i30 too, I’d hope. Or, rather, 1080i59.94 (at 29.97fps).
Yes?
Shane
Little Frog Post
Peter Garaway
July 8, 2013 at 10:48 pmYes sorry. I was just listing the 1080p formats because that’s what he’s using. The entire list is:
1080i50, 1080i59.94, 1080i60, 1080p23.98, 1080p24, 1080p25, 1080p29.97, 1080p30, 720p50, 720p59.94 and 720p60.
Peter Garaway
Adobe
Premiere Pro -
Chris Conlee
July 8, 2013 at 10:57 pmAnd just to be clear, your source footage IS 1080, correct?
Chris
Ericbowen
July 9, 2013 at 6:49 pmGo under Edit and then preferences. Look for the Playback option. Select the Blackmagic playback. Then try the Source or Program preview.
Eric-ADK
Tech Manager
