Activity Forums Adobe Premiere Pro Source Monitor Lag in PP 8.0.1
  • Source Monitor Lag in PP 8.0.1
    Posted by Sibel Zivy on March 26, 2015 at 4:58 pm
    For some reason PP has been lagging on me for unspecified reason..I record games @ 1080p 50Mb/s…
    My system specs are i74930k 16Gb Ram @1600Mhz GtX 760 2gb, I use HDD 2TB for footage, project and cache files but the PP is installed on the ssd.
    Could someone please help or refer a guide/ tutorial to properly optimize PP to fully utilize my system.
    Thank you!
    Ht Davis replied 11 years, 4 months ago 2 Members · 1 Reply
  • Ht Davis
    March 26, 2015 at 10:43 pm
    Cache should be on your internal drive or on a separate drive from everything else, and should be the same place for all caches in adobe for linking to work well. You need a Huge SSD for adobe install. I suggest a fast HDD instead, and set cache internal, with all previews (audio and video in same place) and project files in same place (proxies and project not full prores files only proxies), and keep full formats (AVC or prores) on a fast ESATA, Firewire, USB3 or thunderbolt RAID. This will maximize performance.
    Works for me with 2k files on a 2009 mbp with 2.16ghz core2duo, 4gbram, 256mb gfx.
