Source Monitor In/Out point weirdness working with multiple clips/interpret footage
I have about 7 clips posted up to the source monitor and am using ‘interpret footage’ to take them from 60fps to 30 fps. I set in/out points on the first one and drag it into my sequence no problem.
But when I go to the second clip and interpret it down to 30fps, I’m not able to set in and out points in the source monitor. Tried it with both the i/o keyboard buttons and the equivalent mouse buttons in the source monitor window.
Working with AVI’s out of fraps. One workaround I found is by dragging another clip into the source monitor, then switching back to the clip I wanted to set in/out points for. But why doesn’t it work the way it’s supposed to?
Clay
