Activity › Forums › Apple Final Cut Pro Legacy › Sound waves are not visible in audio viewer
  • Sound waves are not visible in audio viewer
    Posted by Jack Fox on December 19, 2005 at 7:40 pm
    Other clips seem to work but suddenly the wave form is gone. The keyframes and edits are still there but no wave graphics.
    jmf
    Jack Fox replied 20 years, 9 months ago 2 Members · 3 Replies
  • Nick Meyers
    December 19, 2005 at 8:51 pm
    maybe a corruption in your waveform cache?
    check your system prefs to see where the location is
    then go there and delete it.
    ALL your waveforms will have to be re-drawn, though.
    not a real big deal, fortunately
    you could maybe move it first.
    see if that works.
    cheers,
    nick
  • Jack Fox
    December 19, 2005 at 9:47 pm
    Trash waveform files and same problem. Some clips have a waveform and others do not. Those that do not can be seen if you zoom in to the maximum.
    jmf
  • Jack Fox
    December 20, 2005 at 12:01 am
    Well, I moved a source file for one of the clips to the internal hard drive and it flew. Odd, since there were no other problems with the other clips that were located on the external drive.
    jmf
