Activity Forums Adobe After Effects Expressions sound to trigg expression
  • sound to trigg expression
    Posted by Muna Waryanto on June 30, 2010 at 10:19 pm
    can anyone help me how to activate expression with sound..
    i ve read sample from dan ebbert blog, how to wobble a ball,which is
    affecting the scale..
    but i cant modify it for others transform, ie opacity, position..
    please help me…
    thanks
    muna
    Muna Waryanto replied 16 years, 2 months ago 2 Members · 4 Replies
  • Dan Ebberts
    June 30, 2010 at 11:26 pm
    It’s an easy expression to modify, but it’s hard to describe in a general way how to do it. Most of the expression just calculates the variable t, which is how long it has been since the audio level crossed the threshold value. Once you have that you can use it for pretty much any time-based expression. What exactly are you trying to do?
    Dan
  • Muna Waryanto
    July 1, 2010 at 12:15 am
    i try to make layer opacity react with sound
    eg. if the sound reach 10(threshold)the opacity will change to 100 and the other layers opacity 0
    is it possible to make sequences ??
    thanks Dan
    muna
  • Dan Ebberts
    July 1, 2010 at 1:37 am
    Did you look at this one?
    https://www.motionscript.com/design-guide/audio-count.html
    I think it might be closer to what you’re looking for.
    Dan
  • Muna Waryanto
    July 1, 2010 at 3:32 am
    Great Dan…thanks alot
    waryanto
