Activity Forums Apple Final Cut Pro Legacy Sound Synch Problems with Different Video Formats
  • Sound Synch Problems with Different Video Formats
    Posted by Eli Obus on April 18, 2010 at 9:11 am
    Hello,
    I am trying to synch 2 cameras from an interview shoot.
    Camera A is PAL HDV 1080i50 25 fps with 48 khz 16 bit integer audio.
    Camera B is NTSC HD 1080i60 29.97 fps with 48 khz 16 bit integer audio.
    When I synch it, the audio is good for about 2 minutes, and then it slowly starts to become unsynched. Is there any way to fix this other than re-synching every 2 minutes? Thanks a lot.
    -Eli
    John Fishback
    replied 16 years, 4 months ago
    2 Members · 1 Reply
  • John Fishback
    April 18, 2010 at 3:57 pm
    Have you changed the timing of either clip so the frame rate matches?
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
