Activity Forums Adobe After Effects Sound Sync Issues in AE CS4
  • Sound Sync Issues in AE CS4
    Posted by Nick Gay on June 22, 2010 at 2:57 pm
    Hello,
    The audio in my composition is not playing back properly when I do a ram preview. Audio plays back, frame rate is correct, but the audio ques are not sync, essentially the Voice Over kicks in too soon. I opened up the waveform and the waveform looks correct, but I’m getting some audio playback during sections that’s nonexistent. If I move my work area start at the beginning of the next set of audio/waveform, it plays fine, but then the following audio que/waveforms follows right after and doesn’t leave me the 1 or 2 second pause that’s suppose to be there and the original file is timed appropriately.
    Any thoughts?
    Thanks for your help.
    Nick
    Tudor “ted” jelescu replied 16 years, 2 months ago 2 Members · 1 Reply
  • Tudor “ted” jelescu
    June 22, 2010 at 10:43 pm
    If you’re using mp3 files for audio you may get those symptoms. Convert the audio files to wav or aiff and you should be in business.
    Tudor “Ted” Jelescu
    Senior VFX Artist
    Bucharest, Romania
    http://www.ennstudio.ro
