Activity Forums Apple Final Cut Pro Legacy sound problem
  • Posted by John Terry on June 12, 2009 at 7:41 am
    i received videos imported via imovie,
    format is:
    video DV PAL 720×576
    sound DV 1 stereo, 32khz, 32bit floating point,
    when i import them to final cut pro, i can’t edit in real time,
    seems that sound cause problems,
    is this codec not handled by final cut pro?????
    (videos imported via imovie)
    or what i am doing wrong?
    thanks
    john
    http://www.graphixmotion.com
    John Terry replied 17 years, 2 months ago 3 Members · 3 Replies
  • Dino Vince
    June 12, 2009 at 1:57 pm
    make sure your audio settings of the sequence matches the audio settings of the source, this should make the audio come into the timeline, playable without rendering. Alternately, you could export the audio from the source in Quicktime, then replace the audio on your clip. Good luck!
  • John Fishback
    June 12, 2009 at 2:04 pm
    FCP (and all professional edit apps) wants sound files to be 48kHz 16 or 24bit. If it’s not you have to render. But, it’s a quick render. The sound’s sample rate was probably set in the camera. In the future have the camera set to 48k to eliminate the need to render sound. Why didn’t you use FCP to capture instead of iMovie? Not that it would have made a difference with the sound. Did you use the DV PAL easy setup?
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • John Terry
    June 12, 2009 at 8:01 pm
    they are not my videos…so they were imported in imovie…
    thanks!!!
    john
