Activity Forums Adobe After Effects sound levels change in rendered footage
  • sound levels change in rendered footage
    Posted by James Harris on July 10, 2017 at 5:26 am
    In my footage I have to audio tracks ( basic pads) that are cross faded with each other so that when one starts to fade the other jumps, its set up in a smooth way and in the preview everything sounds smooth.
    But when I render the footage it seems that the audio level goes very weak and then jumps back to normal again. Any idea whats causing this?
    Bernard Purcell replied 9 years, 2 months ago 2 Members · 1 Reply
  • Bernard Purcell
    July 24, 2017 at 10:27 pm
    Hi there. I experience this as well, and it is disconcerting, but I think it is just a slow render process.
    If you leave it a little longer – it just goes through the process at the pace it wants too – and finally renders fully and properly.
