Activity Forums Adobe Premiere Pro Sound Forge won’t play Prem 48k audio…
  • Sound Forge won’t play Prem 48k audio…
    Posted by Jerry Cast on June 9, 2009 at 3:29 pm
    When I choose “Edit Original” from Adobe Premier Pro CS3 video editing software, Sound Forge 9 opens automatically because I have .wav files associated with Sound Forge. That’s fine.
    But, I can’t play back the file as Sound Forge says it’s an unsupported format.
    I need to hear the file to edit it and was wondering if there’s a setting to fix this.
    The Sony Sound Forge forum hasn’t had any replies to this problem.
    In case you are wondering why I don’t just use Soundbooth, I do, for fades and stuff like that. But, when I have a stereo audio file that is weaker (smaller .wav file) on one side and I want to make it bigger and even it out, only Sound Forge has the Channel Coverter that has a preset to do this quickly. I saw a channel something or another in Sound Booth but can’t get it to do the same thing, unless I’m missing something.
    Thanks.
    Jerry Cast replied 17 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
