Activity › Forums › Maxon Cinema 4D › Sound Effector and Hair Length
  • Sound Effector and Hair Length
    Posted by Hải Hung hăng on September 5, 2014 at 1:09 pm
    I’m trying to use Sound Effector to control Length of my Hair Object.
    It doesn’t to work though, does anyone have any suggestion,
    Thank you.
    Adam Trachtenberg replied 12 years ago 3 Members · 5 Replies
  • Emir Bojorquez
    September 5, 2014 at 9:16 pm
    I hope this file helps you, just add a Sound inside the Sound Effector.
    7947_emirsoundeffectorhair.zip
    Good Luck
    Imagination is the best tool…
  • Hải Hung hăng
    September 6, 2014 at 4:01 am
    Works perfectly, I think the problem is Xpresso that I were set Strength in the Sample output instead of Weight.
    Many thanks to you Emir,
    Bests
  • Hải Hung hăng
    September 6, 2014 at 6:03 am
    Sorry for keep bothering you,
    I just realize when created a new file, that is connect OutPut from Range Mappper to Hair Object, there are no Length parameter, so how did you do that.
    Bests
  • Emir Bojorquez
    September 6, 2014 at 5:46 pm
    The length is inside the GUIDES Tab Menu.
  • Adam Trachtenberg
    September 6, 2014 at 6:04 pm
    Another option would be to drive the length parameter in the Hair material.
