Activity Forums VEGAS Pro Sound Dropping in Vegas 10
  • Sound Dropping in Vegas 10
    Posted by Brian Brown on May 27, 2012 at 5:47 pm
    OK I am having issue with my sound in Vegas. When I render the sounds does great sometimes and other times it drops in an out after the render. I recently had a project that I changed the noise gate in and it caused the project tracks to do the same thing. I changed it back before rendering. Could adjusting a track inside of a project effect it or what else could be causing it? Thanks for the help.
    Brian B.
    John Rofrano replied 14 years, 3 months ago 2 Members · 1 Reply
  • John Rofrano
    May 29, 2012 at 11:27 am
    [Brian Brown] ” I recently had a project that I changed the noise gate in and it caused the project tracks to do the same thing. “
    That’s what a Noise Gate does. It turns off the audio at a given threshold. You should adjust it so that the only thing below the threshold is unwanted noise. Otherwise it will cut your good audio.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
