Activity Forums VEGAS Pro Sound does not play from audio tracks, but plays in trimmer….also marker is jerky, gets’ stuck’
  • Sound does not play from audio tracks, but plays in trimmer….also marker is jerky, gets’ stuck’
    Posted by Joseph Dezordi on August 22, 2011 at 1:31 am
    The past 2 days, the audio has not been playing from the events in the audio tracks on the time line…
    this was so for both 32 and 64 bit versions…
    How ever if I select them in the trimmer I can hear the audio.
    Also, the marker that moves across the time line no longer moves smoothly, it often lags behind, so you can not really tell exactly where you are
    Joseph D
    Joseph Dezordi replied 15 years ago 1 Member · 0 Replies
  • 0 Replies
