Activity Forums Apple Final Cut Pro Legacy Sound distortion when capturing
  • Sound distortion when capturing
    Posted by Maria-luisa Meredith on November 12, 2010 at 5:59 pm
    Hi
    I have a curious issue (curious to me anyway).
    I’m capturing from a Sony HVR HD1000E via FW to FCP. The recording format was HDV 1080i so I’ve set up FCP to capture accordingly.
    The tape plays video + audio fine in the camera, and fine in FCP BUT when I capture and play back the captured clip the audio is totally distorted! I tried capturing the same clip via iMovie and that’s all fine.
    Any hints as to why this is happening would be greatly appreciated.
    Maria
    Maria-luisa Meredith replied 15 years, 9 months ago 2 Members · 6 Replies
  • Richard Cooper
    November 12, 2010 at 8:04 pm
    Check your “master audio gain” setting in the clip settings tab in Log and Capture window. Try pulling it down and see what happens. The default looks to be set at 1 so try setting it to 0 and see if this helps.
    Richard Cooper
    FrostLine Productions, LLC
    Anchorage, Alaska
    http://www.frostlineproductions.com
  • Maria-luisa Meredith
    November 14, 2010 at 7:31 pm
    Hi Richard
    Thanks for the reply, though I’m running FCP 7.0.3 and don’t see any options in my clip settings window to adjust the audio.
    Maria
    Macbook Pro / OSX 10.6.4 / 2.4GHz Intel Core i5 / 4GB 1067 MHz DDR3
    FCP Studio 7.0.2
  • Richard Cooper
    November 14, 2010 at 8:18 pm
    When you open the Log and Capture window there are three tabs in the upper right corner…. click on the “clip settings” tab and under the Audio settings there is a “master gain” slider. Adjust here.
    Hope this helps
    Richard Cooper
    Anchorage, Alaska
    November 15, 2010 at 2:09 pm
    Hi again Richard
    I’ve attached a link to a screen grab of what I see in my Log & Capture window. Am I looking in the right place?
    Thanks again,
    Maria
    https://www.flickr.com/photos/55932865@N04/5178741536/
    FCP Studio 7.0.2
    Log & Capture
  • Richard Cooper
    November 15, 2010 at 7:46 pm
    Interesting, Yours is different… here is mine…
    I must have these options because I am using a KONA card rather than capturing from Firewire… I am sorry, I guess I am stumped. Do you have another way to capture, like via HD/SDI?
    Richard Cooper
    Anchorage, Alaska
    November 16, 2010 at 9:26 am
    Hi Richard
    Yes, that must be it! Thanks for taking the time to get back. I was able to use iMovie to bring the footage in anyway, so no major hassle. I guess IF the problem persists next time I capture I’ll be doing more ‘investigating’.
    Thanks again.
    Maria
    FCP Studio 7.0.2
