Activity Forums Apple Final Cut Pro Legacy Sound distorting in Sequence
  • Sound distorting in Sequence
    Posted by Maria-luisa Meredith on August 9, 2011 at 10:32 pm
    Hi
    I have a problem which has left me scratching my head. I have a sequence open (1080i50), audio all sounds great but when I’ve exported to QT the audio for one (not both of the contributors, it’s an interview) loses volume and sounds tinny.
    The audio in the original sequence I created sounds fine but subsequent copies of the clip to other sequences again sound tinny etc. What’s going on?
    Any help greatly appreciated.
    Thank you.
    Macbook Pro / OSX 10.6.4 / 2.4GHz Intel Core i5 / 4GB 1067 MHz DDR3
    FCP Studio 7.0.2
    Maria-luisa Meredith replied 15 years ago 3 Members · 4 Replies
  • Jerry Hofmann
    August 10, 2011 at 1:02 am
    Post each “contributor’s’ clip’s properties. What format are the clips and what are the sequence’s settings?
    What format are you exporting your QT’s to?
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Maria-luisa Meredith
    August 10, 2011 at 7:00 am
    Thanks for your response, please find requested settings attached. Both settings are identical for clip and sequence with good sound and bad sound.
    SEQUENCE SETTINGS
    CLIP SETTINGS
    FCP Studio 7.0.2
  • Michael Gissing
    August 10, 2011 at 8:08 am
    My guess is there is a phase cancelation happening. In FCP you are hearing the interview with the two channels probably panned Left/ right. When you make the quicktime you are hearing the two channels mixed.
    Go to the interviews in FCP and try panning both channels to the center. You should hear the phase cancelling. Try muting or deleting one channel and see if that foxes the problem.
    August 10, 2011 at 11:30 am
    I’ll give it a go, thanks.
    FCP Studio 7.0.2
