Activity Forums Apple Final Cut Pro Legacy sound correction
  • sound correction
    Posted by Jason Laville on March 10, 2009 at 11:39 pm
    hi guys im am doing a short film and have just recorded the narration, we used a small quiet room to record and I used a gun mic on my camera. Problem is its picked up a little or slight humming background noise, i could hear it with my ears but the mic picked it up. When in final cut pro is there an audio filter that can make the narrators voice come through and the background slight hum gone?
    Cheers for your time
    David Roth weiss replied 17 years, 6 months ago 6 Members · 13 Replies
  • 13 Replies
  • Russell Lasson
    March 11, 2009 at 12:09 am
    I’d suggest using SoundTrack Pro to reduce the noise. It’s cool because you can choose a point where all you hear is the noise, then tell it to try to reduce that noise throughout the whole clip.
    -Russ
    Russell Lasson
    Universal Post
    Ridgeline Digital Cinema Mastering
    Salt Lake City, UT
  • Dennis Radeke
    March 11, 2009 at 12:40 am
    If you have Adobe CS3 or CS4, you can remove the noise via Soundbooth. It has a unique 3D view of audio and it allows you to identify and reduce noise (like hum, hiss, HVAC, etc) better than any other audio products. I’m an old audio guy and used to sell ProTools quite a bit, so hopefully I qualify what I’m saying (even though I’m an Adobe guy)
  • Michael Gissing
    March 11, 2009 at 1:35 am
    [Dennis Radeke] “reduce noise (like hum, hiss, HVAC, etc) better than any other audio products”
    Really? Better than CEDAR?
  • Jason Laville
    March 11, 2009 at 6:43 am
    thanks guys not sure if i have sound cut pro and dont have adobe, is there no filter in fcp that can help me out?
  • Russell Lasson
    March 11, 2009 at 6:53 am
    Your best bet is to play with eq filters and see if you can filter out the frequency that the noise is coming from. Sometimes this works and other times it effects the dialogue too much.
    -Russ
    Russell Lasson
    Universal Post
    Salt Lake City, UT
  • Jason Laville
    March 11, 2009 at 11:04 am
    cheers mate will give it a go
  • Dennis Radeke
    March 11, 2009 at 12:01 pm
    To the best of my knowledge, CEDAR products do not offer the spectral frequency views that Soundbooth does. Even if it did, I didn’t see any prices lower than $2500 (most were over $10k) and little or no Mac, so I don’t see them as being valid tools for most editors.
  • Dennis Radeke
    March 11, 2009 at 12:04 pm
    Apply a notch filter (AKA a parametric EQ), set the Q (width of freq.) very small, set the amplitude very high and then sweep the freq range to isolate the offending frequency. Then take the amplitude control and take it down all the way. If it’s electrical hum, it’s usually around 60Hz.
  • Mark Landman
    March 11, 2009 at 1:44 pm
    I occasionally get hum from the camera transport picked up by the camera mic. I’ve found that if I use the Parametric EQ filter I can get rid of it. In my particular situation I have to set the frequency to 3280 Hz, set the gain to -20 dB and the Q to 3. You’ll probably have to tweek the settings a little, but this should get you in the ballpark.
    Mark Landman
    PM Productions
    Champaign, IL
  • Jason Laville
    March 11, 2009 at 2:23 pm
    fantastic works a treat thanks so much
