Activity › Forums › Adobe After Effects › sound component error -2166
  • sound component error -2166
    Posted by John Graves on August 7, 2010 at 12:36 am
    Hello ~
    I’m trying to do some fairly simple scenes in AE 5.5 with audio lip syncing to animation layers. I have one very simple project right now with a single layer of art and a single layer of audio. When i first boot into it, it plays, but then moments later, I can’t preview the composition. A bell rings and it says “After effects error: opening sound component (-2166)”
    The sound component is an 8 second stereo wav file. I hardly moved any layer — one moment it plays, the next moment, for no apparent reason, it locks up and gives me the sound error. By “locks up” I’m not saying the program crashes — it just won’t render.
    What am I doing wrong? Would it help if I used another sound format?
    thanks
    John
    “Life is good, as long as it doesn’t take up too much of my time.”
    -anonymous gamer
    Walter Soyka replied 16 years, 1 month ago 2 Members · 3 Replies
  • Walter Soyka
    August 7, 2010 at 12:55 pm
    [John Graves] “I’m trying to do some fairly simple scenes in AE 5.5 with audio lip syncing to animation layers. I have one very simple project right now with a single layer of art and a single layer of audio. When i first boot into it, it plays, but then moments later, I can’t preview the composition. A bell rings and it says “After effects error: opening sound component (-2166)””
    This was a known issues with After Effects v5.5 and Quicktime 7. The solution was to downgrade Quicktime, or upgrade After Effects. AE 5.5 is over 8 years old now, and I’d suspect you’ll have some issues trying to run it on a recent computer with a recent operating system.
    Walter Soyka
  • John Graves
    August 7, 2010 at 2:28 pm
    I have solved this problem by changing the sound file type. I went back to protools and generated the sound file as a Quicktime .mov file…..which seems logical since a .mov file IS a quicktime file. We removed the wav file and put in a mov sound file instead. The problem has totally cleared up and the waveform in the display even looks better.
    Thanks for your support, Walter.
    John
    -anonymous gamer
  • Walter Soyka
    August 7, 2010 at 2:34 pm
    Great — and thank you for posting back with your solution.
    Walter Soyka
