Activity › Forums › Adobe After Effects › Sound AE
  • Posted by Mar Sanchez on December 7, 2009 at 12:19 pm
    Hi
    Is that this is a recurring theme in the forums, But I've been searching endlessly and have not found any solution that serves me to hear my audio After Effects.
    My file is a wav, I care about the timeline and do a RAM preview but although the volumes of audio inspector did not hear anything moving.
    I enabled the option to preview audio and audio composition window enabled both the inspector and the timeline audio.
    Who else can I do?
    Thank you very much
    Mar Sanchez replied 16 years, 9 months ago 3 Members · 4 Replies
  • Tony Brittan
    December 8, 2009 at 4:40 am
    Hey Dave… I’m using the apple Bluetooth keyboard on my mac pro. It doesn’t have a numeric keypad on it. How can I RAM preview with my setup? Can I remap that in AE? I’m totally new to AE so I appreciate it!
    Tony
  • Serge Hamad
    December 8, 2009 at 5:24 am
    Hi Mar,
    I would advise you to rather work with a regular keyboard. But if you really need to use the mini keyboard you could open the shortcuts Text file located here on a MAC:Library>Preferences>Adobe>Aftereffects>YOUR VERSION>Adobe After Effects YOUR VERSION Shortcuts.
    Then look for the following chapter: [“CEggApp”]There you will find the “Preview” command. You would just need to alter it to your taste.
    For example instead of the default:
    “Preview” = “(Pad0)(PadInsert)”
    Write:
    “Preview” = “(Shift+Z)”
    I would advise you though to back up the original file. And to always make sure that you are not using a shortcut that already exist.
    BTW. You could do the same while you are at it to alter the “PreviewAudio” shortcut.
    Salut,
    Serge
    New! InvigoMany-Media volume I & II available here:
    https://www.nyc-visual.com
    Invigorator/Proanimator Training: https://library.creativecow.net/articles/hamad_serge/invig_training.php
  • Mar Sanchez
    December 9, 2009 at 3:11 pm
    Thanks to all
    Of course, I did my RAM preview from the panel control, no from the shortcut (and I also try with the “0” and the “.” shortcuts, but is also not working.
    Any ideas? I can’t find the solution anywhere
    mar
  • Mar Sanchez
    December 9, 2009 at 8:48 pm
    Yeah, I´ve tried before with another projects and wav songs and is always hapenning the same.
    What I have to put in my audio settings?
