Activity Forums Adobe After Effects SOS Newer AE file will not open in older version
  • Tero Ahlfors
    May 4, 2019 at 7:56 pm
    Working as intended, however there should be an option to save the project with support to an older version.
  • Guillaume D’harcourt
    May 4, 2019 at 8:57 pm
    That’s normal, Adobe is not allowing you do open a project saved on a newer update. However, what you can do is on the new AE, click on “Save as -> Save as CC(14) or Save as CC(13), depending on the update you need.
    19 years old french guy, sorry if mistake in my message
