Activity › Forums › Compression Techniques › Sorenson Squeeze Output Looks Filmy…
  • Sorenson Squeeze Output Looks Filmy…
    Posted by Jordan Liles on November 18, 2008 at 8:12 pm
    Hey all. I output a QT movie file in 720×480, looked correct when played back. Then I needed to export it through Sorenson Squeeze and it needed to be MPEG-2 video and audio. However, the output looks filmy. When people move, it looks as if it might not be the correct frame rate, but it is.
    Here are the settings I am using : https://www.isarapix.org/pix0/1227038747.png
    Please let me know if you can think of a fix! Thank you!
    Daniel Low replied 17 years, 10 months ago 3 Members · 4 Replies
  • Daniel Low
    November 19, 2008 at 12:11 am
    What is your source format ?
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
  • Jordan Liles
    November 19, 2008 at 3:56 pm
    When I say “filmy” I mean it looks as if it isn’t running at a full 29.97 or 30 frames per second. It has a different look colorwise in that it looks like it was shot on film and not on a tape. It was shot on tape.
    When I go to movie info on the source, it says:
    Apple DV, 720×480 (640×480), Millions
    16-bit Integer (Big Endian), Stereo, 48,000kHz
    Movie FPS: 29.97
    I wanted to output from my original machine in Avid DV Quicktime format, but Sorenson (upon seeing a file using Avid DV as the video codec) puts the file in the Failed Source folder immediately. It doesn’t try to convert it. So I did not choose “Use Avid DV Codec” in Avid when exporting my original file.
    I’m exporting the MPEG-2 file to our tv station 24 hour system that plays shows on cue. We just recently bought Sorenson Squeeze.
    This any help?
  • Marlon Diaz
    November 19, 2008 at 5:11 pm
    which version of SS u have?
    what is the length of your video?
    what source info you read on ur avid timeline sequence before you did the output to QT?
    seems from what im reading your flow is wrong. You said you already output a QT movie file in 720×480 straight from your avid machine correct? meaning its already compressed to a quicktime apple format, then you want to compress again in SS to mpeg2. Why not try and export just your sequence from Avid and import it to SS and compress to mepg2?
    Im not a avid editor but in FCP you can export a copy of your sequence (timeline), which I then import it in either Apple Compressor or Sorenson 4.5
    Miami, FL
  • Daniel Low
    November 19, 2008 at 7:46 pm
    How are you viewing the MPEG-2 output?
