Activity › Forums › Blackmagic Design › Soooo weird
  • Bob Zelin
    April 12, 2007 at 4:11 pm
    both the Decklink Card genlock input, and the Beta VTR Ref Vid and video input must receive the black signal from the BSG-50 (you have 6 outputs !). You MUST also have the 75 ohm terminator switch to the ON position – because if it is in the OFF position, the Horita does nothing. (open collector output of the BSG-50 must see a 75 ohm path to ground – without the switch being ON, the circuit does not work).
    bob Zelin
  • Chemix Ferreiro
    April 12, 2007 at 4:56 pm
    Thanks Mr. Zelin. I’ll follow your indications as soon as possible and follow up
    BUNKER studio
    “edit in paradise”
