Activity Forums VEGAS Pro SonyVegas movie studio – only trouble encode
  • SonyVegas movie studio – only trouble encode
    Posted by Max Jordan on May 28, 2009 at 9:32 am
    Hallo leute,
    I have something recorded with Fraps (1920×1200), I have the files then SonyVegas inserted after the film and my wish is created.
    Everything looks perfect from.
    Now when I render and
    Example 1:
    Avi as output nehm I select video codec as h624 with an aspect ratio of 1,6 at a resolution of 1440×900 – as audio codec, I would gladly take mp3 but when I select mp3, it offers me no choice – I have only bad übrigt any standard codec to take or pcM uncompressed – both want ich nicht
    Example 2
    Wmv will output – again, aspect ratios 1,6 at 1440×900 – audio is holding the corresponding right codec – so fit
    But no matter what video format I chose – I've always – right at the top left and bottom black bar!! I do not know how I should wegbekommen, The whole film is great but holding on all sides about. 4cm black bar, The aspect ratio fits. The resolution but I've also over the black edge….
    What's wrong with the video codec?
    What can I do as I mp3 codec can correctly?
    Danke für eure hilfe
    Regards
    John Rofrano replied 17 years, 3 months ago 4 Members · 3 Replies
  • Steve Rhoden
    May 28, 2009 at 12:13 pm
    Your post is a bit confusing…still you can try
    opening the event pan/crop window of the
    project on the timeline, then right click in it
    and select match output aspect….maybe
    that will sort out those black bars.
    Or its best then to first have the Vegas properties
    set to the resolution you are rendering out to….then
    select the match output aspect.
    Steve Rhoden
    (Cow Leader)
    Creative Arts Director and Film Maker.
    Project Samples at:
    http://www.youtube.com/hentys
  • Douglas Spotted eagle
    May 28, 2009 at 1:19 pm
    you need to be using square pixels on output, not anything else. Some players cannot read non-square pixels.
    Why are you using an odd resolution such as 1440 x 900? do you need to fit a specific window?
    it’ll still work, just curious.
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • John Rofrano
    May 28, 2009 at 3:53 pm
    Also some codecs require the resolution to be evenly divisible by 8 and 900 doesn’t divide evenly by 8 so it must pad the picture with black pixels to make an even 8 pixels for the encode.
    Try using 1/2 the normal resolution 960×600 and see if that encodes better. That’s still a good size for web delivery.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
