Activity Forums VEGAS Pro SonyVegas Doubts
  • SonyVegas Doubts
    Posted by Victor Fernandes on September 24, 2015 at 1:36 pm
    Hello everyone,
    This is my first post on this forum however I’ve been visiting so much time and whenever I have a doubt.
    Since I’m limited at English I will be direct to the point:
    1. Whenever I want to cut certain parts of a video I select the frame where I want to cut, press Right Click and then “Split” and do the same to the end and delete that part of the video.
    Now, can I also do that with the audio? The option isn’t available for me, the purpose is to cut some parts of the audio or simple leveling the volume.
    2. I record gameplays and full resolution ( 1366×768 60fps) and I set the bitrate to 8Mb/s and when I export my settings are:
    1280x720p 60fps
    Target bitrate: 8
    Max bitrate: 8
    I like the quality of the videos even when they are at YouTube I just want to know if I can improve those numbers, like having Target bitrate at 8 but Max Bitrate at 10, I’m not doing nothing wrong here, right? Or it is completly fine?
    3. Final question, how do I animate image to come from far to very close but watching what I’m doing in real time? I mean, in After Effects I can slide the “thing” and adjust the keyframes and watch how it will be but in Vegas I have to do it blindly.
    https://www.youtube.com/watch?v=J_erWrSUhTk
    How can you see, in that video I made, the text “Insurgency” (to be honest is a PNG image) to come from far but I wanted tiny but the editing is very sensitive, and in the end it feels very clunky, I wanted to come as close as possible but then the image was cutted above in bottom , don’t know why. I did all of this blindly since I adjusted the keyframes without seeing it how it would end, more like trial and error.
    Anyways, these are all the questions I have, if something feels confusing I will try to improve and be more specific in my writing.
    Thank you all.
    Bill Burnette replied 10 years, 11 months ago 3 Members · 2 Replies
  • Aaron Star
    September 25, 2015 at 1:09 am
    1 – try adding a blank track above your timeline clips to do your cursor movements. Selecting this track and timeline spot, hitting S, will cut both audio and video below the track.
    2 – 720-60P on youtube is 8Mb/s. Your source should be captured at more like 12-16Mbs. edited and uploaded at 12-16mbs. this allows YT to “throw away” info to get to a good 8Mbs. Editing source mp4 files is not really an optimized way to work in vegas. Recording something like XDCAM422 or EX, or source recording mp4 footage to 16-28Mbs, then converting to XDCAM 60p would be a better way of editing.
    Also setting your game to a Video standard resolution would something else to look into. 720p is 1280×720, HD is 1920×1080. Changes your game settings to match those resolutions.
    3 – Not sure about this question, and it sounds like you just do not know the edit controls in Vegas very well.
  • Bill Burnette
    September 25, 2015 at 5:09 am
    3. See if this is what you need: Look for the little lock icon in the pan/crop window. Click to lock. Then the time control in the pan crop window will lock to the time control on the main timeline, so the panned/cropped image will show in the main preview window as you operate in the pan/crop window.
