Activity › Forums › VEGAS Pro › Sony7 Veagas pro 10 Stops Responding if i open another folder or programme
  • Sony7 Veagas pro 10 Stops Responding if i open another folder or programme
    Posted by Hayley Gommersall on November 11, 2010 at 3:46 am
    Hi all I have just upgrade to sony vegas pr0 10 from vegas 7. When i start vegas and open a project it takes about 5 min to load, is this normal for pro 10.
    Also in the preferences Tab under video i have change the Show source to Head, Tail. In the Dynamic RAM Preview max what is the best value here.
    In the audio Tab i have changed the Waveform display while recording as Dont show Waveforms but the waveforms still show in project, the waveforms seem to take the longest to load up when opening a project.
    My computer specs are:
    – Pentium®DC & Core™2 & Quad Core 2x PCI-E 16x SLI Ready Slots, 2 x PCI, 2 x PCI-E, 4 x DDR2-
    800(Dual), 4 x SATA2 RAID, 1 x ATA100, 8 x USB 2.0, Gigabit LAN Durability Series – All Solid
    Capacitors, 8ch Audio, ATX
    – Gigabyte® Triton 180 Chassis – Black – Aluminum Bevel – 5 x 5.25″ & 5 x 3.5″ Bays – 1x Rear & 1x
    Front 120mm Fans, No PSU
    – Transcend® JetRam™ High-Performance 2GB DDR2-800 240-Pin Module : CL5, 4-Layer PC Board,
    Life-Time Warranty
    – LITEON® DVD LightScribe Super All-Write SATA, 20x+R/-R, 8x +R/-R DL, 8x +RW, 6x -RW, 12x –
    RAM, 16x DVD, 48xCDR, 24x RW, White & Black
    -Seagate® Barracuda™ 7200.11 Series – 750GB Serial ATA II (SATA2) Plus – Serial ATA 300 (3Gbps)With 32MB Cache @ 7200RPM – NCQ
    -Seagate® Barracuda™ 7200.10 Series – 250GB Serial ATA II (SATA2) Plus – Serial ATA 300 (3Gbps)With 16MB Cache @ 7200RPM – NCQ
    – Gigabyte® NVIDIA® GeForce 8600GT, 512MB 128Bit GDDR2, Dual DVI, HDTV, DirectX10, OpenGL,
    Dual RAMDACS, SLI Ready, Silent Pipe II
    – GIGABYTE® Superb 550W 24-Pin Power Supply, 3 Molex & 4 SATA Power Connectors, Intel LGA775
    Ready & Approved, Includes Power Cable
    Transcend® Multi Card Reader – USB 2.0 WHITE – Supports CF, SD, miniSD, MicroDrive, MMC,
    Reduced MMC, MMC Mobile, Memory Stick, xD
    – 3 Port PCI Firewire Card
    Do you see anything that needs to change to make my computer respond better to vegas pro.
    Vegas pro10, is a big jump from vegas 7 i see, not just in the look and feel but also my computer is feeling the extra processing power needed to run pro 10.
    It seems when i am in vegas pro 10 working on a project if i move away and open a folder or media player vegas stops responding and i have to go to task manager to close it down.
    Can anyone help me with all these questions
    John Rofrano replied 15 years, 10 months ago 3 Members · 4 Replies
  • John Rofrano
    November 11, 2010 at 9:23 pm
    You gave us the specs for everything but your processor. I beleive that this:
    “- Pentium®DC & Core™2 & Quad Core 2x PCI-E 16x SLI Ready Slots, 2 x PCI, 2 x PCI-E, 4 x DDR2- 800(Dual), 4 x SATA2 RAID, 1 x ATA100, 8 x USB 2.0, Gigabit LAN Durability Series – All Solid Capacitors, 8ch Audio, ATX”
    Is the specs of your motherboard which can accept a Core 2 or QuadCore but which do you have and how fast is it?
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Stephen Mann
    November 12, 2010 at 5:08 am
    Setting Dyamic RAM preview to a high value steals available RAM from rendering. Try setting it to zero.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Hayley Gommersall
    November 14, 2010 at 4:11 am
    Thank you Stephan for your response i have lowered it quite a lot and seems to be ok, thanks for replying.
    Hayley Gommersall
    FlyontheWall Productions http://www.flyproductions.co.za
    A media company focused on filming, editing, DVD Resource Development and Web Design.
  • John Rofrano
    November 14, 2010 at 1:26 pm
    [Hayley Gommersall] “Thank you Stephan for your response i have lowered it quite a lot and seems to be ok, thanks for replying.”
    For the benefit of others… what was it set at and what is it set to now? RAM Preview steals memory from other functions in Vegas (including rednering) and only uses it for performing RAM previews (Shift+B) so it is best not to set this too high.
    ~jr
