Activity › Forums › Apple Final Cut Pro Legacy › Sony Z1 print to tape problems FCP 5 HDV Format
  • Sony Z1 print to tape problems FCP 5 HDV Format
    Posted by Tim Kuhlman on June 13, 2007 at 7:52 am
    I researched several post on this topic and still can’t get this to work. Here’s my situation. I have imported and edited my HDV footage in the HDV easy set up in FCP 5. I now want to record this HDV sequence (in HDV format) back to a Sony Master tape using my Z1. I am working in a PAL environment and have dbl checked all my settings on the camera and within FCP and I still can’t get the video to output. I just get a blue screen on my camera monitor. Can the Sony Z1 even record back to tape in HDV format? When I have the IN/OUT Rec setting set to HDV, REC MODE is greyed out. Only when I have this set to DV or Auto is the REC MODE open to changes. I have my camera set to VCR and the settings are these on the camera:
    IN/OUT Rec: VCR HDV/DV is set to HDV (Thats what I want to record in, yes?)
    REC MODE: Greyed out
    Component is 1080i (Pal)
    iLink is set to off
    A/V to D/V Out is off
    Final Cut Pro settings: (Audio Video Settings)
    Summary Tab: Sequence Preset is: HDV-1080i50
    Capture Preset is HDV
    Device Control: Sony Firewire
    AV Device Tab:
    Playback Output Video: NONE
    Audio: Default
    “Different Output for Edit to tape/print to video” Certain settings are greyed out. On this it depends on what my camera is set to in the IN/OUT Rec setting.
    Please, any suggestions would be greatly appreciated. Been trying to get this to work for days.
    Tim
    Charlie Inman replied 16 years, 9 months ago 3 Members · 3 Replies
  • Adam Taylor
    June 13, 2007 at 11:46 am
    rtfm….
    page 98….
    “to import pictures from the computer to your camcorder.
    In the HDV format –
    set [VCR HDV/DV] to [HDV] (p.71) and
    [HDV-DV CONV] to [OFF] in [i.LINK CONV] (p.74)”
    you need to have the camcorder connected via I.LINK / Firewire.
    hope that helps
    Adam
    Editor/Mixer
    Character Options Ltd
    Oldham, UK
  • Tim Kuhlman
    June 13, 2007 at 12:42 pm
    Thanks for the reply Adam. Yes, I have the firewire connected
  • Charlie Inman
    December 15, 2009 at 7:54 pm
    I am having exactly the same problem. Did you get it fixed? I need to deliver tomorrow. Driving me mad.
    Cheers. Charlie
