Activity › Forums › Sony Cameras › Sony XDCAM Transfer – Subclip Problem
Jimmy Garland replied 17 years, 6 months ago 6 Members · 17 Replies
Ron James
August 17, 2008 at 5:44 pmThat’s excellent, Don! Thanks a lot for taking the time to pass on these settings. I’m working this evening, so I’m going to go through all of these. I’m thinking I’ve got to be missing something simple, especially based on the fact that it’s happening to me on two different machines with two different versions of the Transfer software. Strangely, v.1.1 works fine for me.
Weird.
Ron James
August 18, 2008 at 4:24 amDon, I checked all those pref’s and a few were different. I also updated to 2.7.1.
Now I’m getting an error with subclips: “cannot read file (insert name of mxf file)”
Everything else still works fine.
When you mentioned the camera it made me think I neglected to mention I’m using a deck (PDW-F70). My next plan is to check all the deck settings. Ugh, frustrating.
Thanks again for your help,
Ron
Don Greening
August 18, 2008 at 4:33 amYeah, I wouldn’t have a clue about the deck settings. One way to find out if it is the deck is if you were able to copy an entire BPAV folder from an SxS Pro card to your computer and then start the Transfer Tool, navigate to the BPAV folder and see if you can import a subclip from that. If you can then it’s something to do with the deck. If the deck contains separate BPAV folders previously transferred from cards try copying one of those to your hard drive and accessing that within the Transfer Tool.
– Don
Ron James
August 18, 2008 at 8:45 pmThat’s a good idea! I’m going to try that. At least, I’ll be able to eliminate yet another factor. The deck only seems to have one setting related to this, which is FAM (setting it to file transfer mode) but who knows.
Thanks, Don.
Tony Gordon
October 17, 2008 at 10:52 amHello Gentlemen I am in REMOTE Jungles of Cairns Australia – I have FCP v 6.0.4 on Mac Pro Intel OS is 10.4.11
I am having massive issues with XDCam Transfer —
I have today installed ALL updates and loaded FCP Studio 2
When I launch XDCam Transfer I get this error-
ERROR INITALISING DATABASE
The application does not support this version of the offline database
The application supports Version 7 but this is a Version 8 Database…any iseas ???
I have removed the preferences with no effect…
tony
Michael Palmer
October 17, 2008 at 1:14 pmI’m running Quicktime 7.5.5, OS 10.5.5, and XD Cam Transfer 2.7.0 on my MacBook Pro 2.4 with no issues. Can you provide the software versions you are working with? You also need FCS2 updated to at least 6.0.2.
Good Luck
Michael Palmer -
Jimmy Garland
March 27, 2009 at 9:40 pmI had the same database error. You need to install browser software that came with camera to make it work. good luck
