Activity Forums Sony Cameras Sony XDCAM Transfer – Subclip Problem
  • Sony XDCAM Transfer – Subclip Problem
    Posted by Ron James on August 15, 2008 at 3:20 am
    I’m using Sony XDCAM Transfer 2.5.1 on a Mac Pro running OS 10.5.4. In an earlier version of the Transfer software (1.x.x) I was able to import subclips without importing the entire master/source clip. I haven’t been able to do this on any version of 2.x.x. I was hoping this update would change that, but I’m still getting the same problem. I used an earlier 2.x.x on an iMac 24″ and it had the exact same problem.
    If I mark a subclip and import, it creates a 4k empty movie file. I’ve tried tweaking the preferences, but nothing changes. I even tried importing straight to the desktop as opposed to an external FW drive, but no difference.
    Anyone else having the same problem. Or not having this problem??
    Jimmy Garland replied 17 years, 5 months ago 6 Members · 17 Replies
  • 17 Replies
  • Don Greening
    August 15, 2008 at 5:02 am
    I’m not having this problem. I can select an in point and an out point in the Transfer Tool viewer window and the program will only import that specific portion.
    I’m using XDCAM Transfer Tool v.2.5.1 with OS 10.4.11 and QT v. 7.3.1. on a Mac Pro dual core 3 Ghz. There’s no difference if I use the Transfer program as a stand alone app or from within FCP 6.
    – Don
  • Ron James
    August 15, 2008 at 5:59 pm
    Don,
    I wonder what the heck is going on. You’re using OS 10.4.1? I wonder if it’s a Leopard issue, then. What a pain.
  • Don Greening
    August 15, 2008 at 6:15 pm
    [Ronnie James] “You’re using OS 10.4.1?”
    I’m using OS 10.4.11, not 10.4.1.
    Perhaps it is a leopard thing but I’m sure there are lots of users running the same setup as yourself without issue. You could try trashing the Transfer Tool preference file and then trying another subclip transfer.
    You can find the pref. file here:
    Macintosh HD>Users>”yourname”>Library>Preferences>com.sony.bprl.xdcamtransfer.plist
    Drag that file to the trash and restart the XDCAM Transfer app. and see if that solves it.
    – Don
  • Ron James
    August 15, 2008 at 6:19 pm
    Oh, I forgot Tiger went up to .11 so I thought it was a typo.
    I’ve tried the pref trashing and everything else I can think of. And it happens on two different computers: a 24″ iMac and a Mac Pro dual 3 (both running Leopard).
  • Don Greening
    August 15, 2008 at 6:23 pm
    Very strange. Must be a leopard thing then or maybe a combo of Leopard and perhaps your installed version of QT. I don’t have OS 10.5 on any of my machines yet, so I can’t try and duplicate your issue.
    But you can still transfer whole clips without a problem, right?
    – Don
  • Ron James
    August 15, 2008 at 6:44 pm
    Don,
    Yes I can still do whole clips. I even tried taking in subclips alongside the whole clips, but I just end up with the same empty movie files. Hopefully, someone with Leopard can chime in, too.
    A quick question for you, though: do you have any external FW drives hooked up to your system? I’ve noticed some issues with clips failing on import when multiple ext drives are hooked up, but that was on an older G5. I didn’t think to try unplugging the Firewire drives and I’m not at work right now, so I can’t try, but thought I’d ask you.
    Grasping at straws now, but sometimes the weirdest things end up being the culprit.
  • Don Greening
    August 15, 2008 at 8:47 pm
    [Ronnie James] “do you have any external FW drives hooked up to your system?”
    Yeah I do but I’m not using them for transferring footage via Sony’s Transfer app. For that I have an internal SATA media array (3 drives) in the Mac Pro.
    – Don
  • Brian Walker
    August 16, 2008 at 7:10 pm
    I have leopard 10.5.4, and XDCAM Transfer 2.7.0 and I can transfer subclips no problem!
  • Ron James
    August 17, 2008 at 12:54 am
    Thanks a lot, Brian!
    I should try the newer version of XDCAM transfer, perhaps. I thought I had the latest, but apparently not. If you have any ideas of what else I might be missing (even obvious) please let me know.
  • Don Greening
    August 17, 2008 at 5:27 pm
    Ronnie,
    I just did a subclip test for you where I selected about 5 sec. of footage from a 58 minute clip right from the camera hooked up to my Mac Pro via USB. I selected my in and out points right in the Transfer Tool viewer window and then hit import. Worked just fine.
    Maybe it’s a preference thing that’s checked or not checked but here is a rundown of how my Transfer Tool prefs are set up so you can compare.
    Under General prefs:
    Automatically add media – checked
    Show offline media – checked
    Audio channels – all checked
    Under Cache prefs:
    Cache size is set at 10%
    Automatically fetch proxies – checked
    Under Import prefs:
    New folder for each source – checked
    Overwrite existing files – not checked
    Add source name – checked
    Add clip title – checked
    Add UMID – not checked
    For subclips add in and out timecodes – checked
    For subclips add index number – checked
    Subclip handles – not checked
    Only import monitored channels – not checked
    Write Final Cut Pro XML file – checked
    Uncheck subclips on import – not checked
    Open imported files with – not checked
    See what happens when you compare your prefs.
    – Don
